Highpoint 2320 RAID5 Information
EnderW
Anyone with a Highpoint 2320 RAID5 array check in here. Here is the info I'm looking for:
1) HD Tach Tests
2) Read/Write Performance
3) What disks you're using
4) Number of disks
5) Rebuilt time
6) Comments and your overall opinion of the card
Thanks
1) Not available, as I'm running Linux on XFS. Here are my bonnie++ results:
Code:
Version  1.03       ------Sequential Output------ --Sequential Input- --Random-
                    -Per Chr- --Block-- -Rewrite- -Per Chr- --Block-- --Seeks--
Machine        Size K/sec %CP K/sec %CP K/sec %CP K/sec %CP K/sec %CP  /sec %CP
Fedora5         10G 34637  90 71612  25 38922  15 38857  92 176716  28 193.7   0
                    ------Sequential Create------ --------Random Create--------
                    -Create-- --Read--- -Delete-- -Create-- --Read--- -Delete--
              files  /sec %CP  /sec %CP  /sec %CP  /sec %CP  /sec %CP  /sec %CP
                 16  6665  62 +++++ +++  5498  51  6996  67 +++++ +++  3825  42
Fedora5,10G,34637,90,71612,25,  38922,15,38857,92,176716,28,19  3.7,0,16,6665,62,+++++,+++,5498,  51,6996,67,+++++,+++,3825,42
[dew@Fedora5 root]$ df -B 1M | grep terabyte
/dev/sda1              1220475         9   1220467   1% /mnt/terabyte
Block Read: 176,716K/sec
Block Write: 71,612K/sec
WD3200JD 320GB SE (8MB Cache)
4) Number of disks
Currently: 5
Next week: 6
5) Rebuilt time
Last rebuild(with raid at 90% full): 2.5Hours.
Love it, OCE is a life saver. I'll be using it a SECOND time next week.
