highest static pressure fans
64ninjas
Hello, I was wondering if anybody could tell what are me some of the highest static pressure fans on the market? Noise is not a concern but power draw needs to be 50W or less.
What size are you looking for?
50W is a POWERFUL fookan fan
I almost need something between a fan and a compressor. non pc related project.
100cfm minimum rating. no larger than 250mm lol
In 120mm size you may try the 120mm Sunon. Be sure to get the 35mm think model. Extra thickness allows for more aggressive blades.
172mm is the way to go if you want to move some air. Or the 254mm/550cfm Comair Caravel if you are really serious. Requires a 12-24v adaptor.
One note - - smaller fans have higher static pressure to CFM ratios then larger ones.
