Highest FX-60 Watercooled OC?
not possible. although i have seen a fx57) do 3.97 on dry ice.. it was in the top ten i belive but heres a link of it on ebay! the auction has already ended but u can still view it, and if the link doesnt work let me know. oh hey dude i noticed in ur sig it says the catalyst 5.13 gave u a boost well the 6.1 are the exact same as the 5.13 with just a little more features so i would get them! how are you getting 7100? i understand your cpu is OCed much faster but what are your cards clocks?
http://cgi.ebay.com/Retail-AMD-Athl...ryZ80140QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
um for benchmarking i think i ran it at 600/620 or i might have done it at 610/625..i cant remember but i usually keep the card at around 570/600 for gaming
max stable oc is around 585/610 once i get past that the card will run for 30mins then artifact...temps are under 65 degrees i think i may have to up the voltage or something :p
infinity4life said:
nope, your core must just suck. I hit 6.5ghz with stock cooling. Honest.
What a joker we have here :eek:
FX60 might be able to do 3.1 Ghz on watercooling but i can't imagine it being dual stable beyond that. That's already being generous.
Yeah no doubt there...the highest I see my self pushing it on WC is 3.1 stable...and that's calling it close
{NcsO}ReichstaG said:
wouldn't the signal turn into Microwave or something..or some physical weird affects would occur...?
(6.5 total ghz)/(2 cores)=(3.25 ghz per core)
not that far out of the realm of possibility.
I think i saw Dumo at Xtremesystems break through the 3.4 or 3.5 Ghz barrier on his FX60. He has some good phase cooling ;)
..i was thinking of 6.5Ghz per core. With that kind of thinking,i can claim i have a 5.2Ghz processer (2x2.6Ghz per core). But that's not true...
Pretty sure there's some links around here to some mid - low 3.x GHz on the FX60
I can boot into windows at 3.0GHZ on air but won't run intensive applications....
With the week 36 FX60's that a lot of us have right now I would think a stable 3G's is tops. Mine fails the dual p95 test at around 4 hours at 1.5v running at 250HTT x 12. It passes Super Pi and everything else except p95. Giving it more juice doesn't help a lot.
Here is a guy over at OCAU at 3G's at 1.6v. I haven't seen anyone on water doing much more than that.
that's good to know because I've had trouble going above 3g's stable too...however I got it so I could go up to that speed at only 1.40v...I just ran CPUburn for 24 hours and I was able to lower my voltage...I was able to get Prime95 to run for 9 hours...I think i would have kept going but I turned it off...I'll have to test it longer next time
Read about someone who pulled 12 Ghz using a liquid nitrogen cooling loop... was stable... for 12 seconds.
And no, the signal will not turn into microwaves... however, it will open a gate to hell, release the four horsemen, locusts will cover the earth, it'll rain hail and fire, I'll become a democrat, the mountains will fall, dogs will sleep with cats...
mituhide said:
here maybe the highest X2 3800+ ;)
CPU AMD Athlon(tm) 64 X2 3800+ @ 3557 MHz
NVIDIA GeForce 7800 GTX 512 SLI
Core Clock 779 MHz
Memory Clock 2160 MHz
3DMark05 Score 19043 3DMarks
http://service.futuremark.com/compare?3dm05=1745035
3DMark06 Score 11934 3DMarks
http://service.futuremark.com/compare?3dm06=78616
SM 2.0 Score 5562 Marks
SM 3.0 Score 5443 Marks
CPU Score 2727 Marks
Why is the FSB on those194 . are they unlocked UP? I thought only FX's were unlocked up . That memory speed makes me think this is another cheat score.
Could some one tell me how on Amd you can O/C the Cpu without increasing the FSB with locked up multipliers. I no there unlocked down.
This guy is incrediable he can O/C x2 higher than the rest . :eek: he can O/C the GPU 2 of them better than the rest. :eek: and his memory O/C is rather good to I bet its 2-2-2-5-2 also :eek: LOL
This is better than the intel cpu setup that was at the top of the orb 1 month ago cpu speed 32000ghz sli 6800's 20,000+points. That guy was found to be a cheat I am betting this guy is also . I admit this one is more believable
Forget about the unlocked up I was thinking backwards . He lowered his multipliers than clocked up the memory to get to a 194 FSB . Been a long day .I still thinking he's cheating or has the worlds best cooling system.
Ok I just went to the orb and checked things out. This guy is just plain ass good . I believe his scores completely . I like his handle to The chosen one.
$BangforThe$ said:
Why is the memory on those running 194 . are they unlocked UP? I thought only FX's were unlocked up . That memory speed makes me think this is another cheat score.
That's impressive considering my BFG's won't OC 1MHZ higher than their factory settings....
