Unfortunately, mobile Athlon XPs will not work correctly on the NF7-S2 motherboard. There is no multiplier adjustment at all whatsoever on that mobo. On a "400MHz" (200MHz actual clockspeed) FSB, the CPU may use a default PowerNOW(tm)-enabled multiplier of 9 on that mobo. As a result, it will only run at 1.8GHz. That would be roughly the speed of a stock desktop AXP 2500+. Any CPU that is to be used on the NF7-S2 must be multiplier-locked; otherwise, it will not work correctly.BlackCoffee said:Yeah I'm almost 99% positive that a 3200+ will run properly on a NF7-S.
But man, buying a 2600+ Mobile and simply changing your FSB doesnt sound enticing to you? Cheaper and stuff?
But anyway, have fun w/ the new CPU, cheers m8.
FX25 said:whos ass did you pull that story out of eagle. i am quite sure i m running a moblie at 2.5 gigs right now. so you might want to think b4 you post.
