Higher voltages with Aida64 Stability Test
Araxie
Hi all ppl, I was making some test on my system with the specification on Signature, but in this case all stock settings.. the concern is in this moment the System Stability Test on Aida64 are showing higher Voltages on the CPU than any other Stress Test like Linx or Prime95 Blend torture test.. is this normal or an issue with aida64??. voltages with P95 are CpuCore: 1.168, VID: 1.236, also extra +3.3: 3.360, +5: 5.080, +12: 12.000.. same as other stress programs.. but when i throw Aida64 it show: CpuCore: 1.184, VID: 1.251, also extra +3.3: 3.360, +5: 5.120, +12: 11.904
Also for some reasons in Aida64 the idle temps are 5-6°C higher than other monitoring programs like [CoreTemp 1.0RC5 And RealTemp 3.70] but load temps seems fine 1-2°C at most different.. im idling in core temp at 25/25/25/25 but aida64 show 31/32/30/30 load temps 44/46/45/43 not vary much in aida64 45/48/48/45 but are still differents.. realtemp are coretemps or even HwmonitorPRO are identical all the time..
well i post some images of the concerned theme the voltages:
Aida64:
Prime95 Blend:
Any help guys?... Any xpert in theme of voltages plz.. X_X
Software voltage readings are forever inaccurate. Only way to get good readings is with a multimeter, on a motherboard with voltage contacts.
Thx for the answer bud, i know thats is.. But the software for monitoring in this case its the same, the only change its the stress test used.. In this case Aida stress test, linx and prime95 blend.. Linx and prime95 show same range of voltages but when stressed with aida show different voltages kinda high... I'll try however directly on the mobo.. But i guess the same readings will happens...
Ok after a time i'd decided to make some test directly on the mobo. And the results are the same as show in the images... Differents voltages with the stress of aida64 than p95 and linx... Juist in the case that with aida i got even higher cpu voltage at 1.192v... With the others remain stable at 1.168.
