You have an Opteron 148 and an X850XT PE and you can't buy a used 19" CRT for $50-100...contaminant said:My monitor is my downfall. I am stuck at 1024x768, so I just max out AA and HQAF to make up for it. I play all games 10x7 with full AA and HQAF and they look pretty enough.
Dark_fire said:on the 7800 and 1800/1900 AF is basicly a free eye candy. effects performance by what, 1-2 FPS
No, I'm just waiting. I need a new monitor, and when I get a new monitor it is going to be bigger than 19"Borgschulze said:You have an Opteron 148 and an X850XT PE and you can't buy a used 19" CRT for $50-100...
That's... laziness.
Well, a potential solution is to get a smaller LCD.Zinn said:I can't run anything except 1680x1050... Can't stand the way it looks at non-native resolutions. I will make compromises with eye candy sometimes, but more often, I'll just try to have the fastest graphics setup I can afford.
I find the 2005fpw is barely large enough for the work I do... I might consider a second smaller monitor to play games and work on, but then there'd be no SLI for me.dderidex said:Well, a potential solution is to get a smaller LCD.
I'm not a fan of running non-native, either, but just picked up a Sony X-BRITE LCD, and *holy crap* it's awesome looking! Only wish there was a manufacturer that did S-IPS panels with this type of tech instead of just sticking with TN panels for it. IPS has a noticeably superior range of colors, but WOW the colors the X-BRITE does display are breathtaking. Quality of display alone, I'm happier with this monitor than with the Dell 2005fpw. Plus, hey, lower res = higher FPS.
You devil!contaminant said:No, I'm just waiting. I need a new monitor, and when I get a new monitor it is going to be bigger than 19"![]()
Zinn said:I find the 2005fpw is barely large enough for the work I do... I might consider a second smaller monitor to play games and work on, but then there'd be no SLI for me.
