Sounds like some of the inductors in your computer are vibrating. It won't cause any problems, but it can be annoying. Try isolating the source of the sound by grabbing a piece of tubing, putting one end next to your ear, and probing around the inside of the computer with the other. I suspect the noise is coming from either the motherboard or from the PSU. If that is the case, you can RMA the component responsible if you really want to get rid of the noise.
