Jan 18, 2004 #1 O _orcus_ 2[H]4U Joined Nov 21, 2001 Messages 2,554 I have a P4 2.4C on a P4P800 that can run at 250 fsb with the memory 3:2 or at 240fsb with the memory at 5:4... Will the extra memory bandwidth be noticeable if I go with 5:4 and lose 100 mhz? Thanks.
Jan 18, 2004 #2 Evil Scooter [H]F Junkie 2FA Joined Sep 22, 2000 Messages 9,124 Depends on what software you are running. Most games seem to prefer memory bandwidth over a slightly higher CPU clock.
Jan 18, 2004 #3 C chrisf6969 [H]F Junkie Joined Oct 27, 2003 Messages 9,011 run some BENCHMARKS on your machine and see!! newb cheeze Run the type of benchmark that you're interested in. If you're a gamer, run 3dmark 2001. If you're an office user run some Bapco or Winstone type benchmark. If you're a video encoder do a few test encodes and time the same file at the 2 different settings. You can also run sisoft for a quick references to see what your CPU & memory scores are at each setting.
Jan 19, 2004 #4 M MemoryInAGarden 2[H]4U Joined Oct 26, 2003 Messages 4,067 The video encoding would probably be better at 250, but more bandwidth intensive games would be better off at the 240
