High tower pc case recommendations please
smodtactical
I have been searching for a high quality high tower case. So far my #1 choice is 1000D but its a bit pricey and filing it with rgb fans would make it even more pricey. I am coming from a 900D which i really like but I am going to leave this system intact as a second PC. Phanteks enthoo pro 2 seems decent. View 71 (and 91).
Any other thoughts on something really well made and a high tower? I made do a custom loop but not 100% decided.
I like my p600s a lot but not sure that’s big enough for you. Fleabay is also full of gems. Stacker 830, missing the fan mount thing with the 4 side fans but who the hell cares. Thing was 110 after everything and only very minor cosmetic issues.
NightReaver
Sorta in the same boat as you, lol. Using a 900D which has been great...except I find myself encountering little annoyances here and there.
Where we part is that I decided to go back to the drawing board (or in this case SketchUp) and design my 2nd huge wooden case with lessons learned about what I actually do want in a case.
Aside from that, I don't really know too many large tower cases nowadays. As for the 1000D, I know that Zarathustra[H] has a pretty in depth thread on his custom looping adventure in it: https://hardforum.com/threads/the-z-build-2-0.1993068/
That might help you avoid a few annoyances if you happen to get one. Good luck!
