wasteomind
- Aug 13, 2004
I just installed a second loop into my system for my gpus. It consists of:
XSPC dual bay res/pump combo (mcp655 pump)
XSPC RX480 4x120 rad
8 Gentle Typhoon AP-15 in push/pull
2x XSPC Razor gtx 680 water blocks
The only thing in the loop are my two GTX 680 reference models. This should be over kill for them however I feel like the load temps are high.
Room ambient = 20c
Idle = 24-25c
Load = 43-48c (top card) and 50-55c (bottom card)
The loop follows the same general flow most others do :
Res/Pump > Rad > Gpu 1 > Gpu 2 > repeat
Most other load temps I have read about are high 30s low 40s on sli and tri sli systems. The only thing I can think of is that I used the included XSPC generic TIM when installing the blocks. It wouldn't make that big of a difference would it?
Room ambient = 20c
Idle = 24-25c
