yallknowho
- Dec 26, 2005
I bought a E6300 and 965P-DS3 back in august and finally got around to trying to oc it.
now as far as cooling goes, the side of my case is open and im running a Zalman CNPS7000B-ALCU on the CPU and a HR-05 on the northbridge. Im also running bios version F11.
without overclocking (266 FSB, 1.8ghz) my idle temps were 40C and after 5 min of orthos 58C.
Now i'm running 1.35v on the cpu and 366 FSB at 2562mhz my memory is running only at 1.9v
my idle temps are 42C, 3 min of orthos had me at about 63C.
Whats going on?
earlier tonight I booted up at 400 FSB at about 1.35. It froze after a couple minutes in XP, under very little activity. I cranked the volts up to 1.375 and it would be more stable, but then I tried to run orthos and after like a minute im at 65C. The second time the system froze.
Back when I was testing my memory, i was running my corsair TWIN2X2048-6400 at 963mhz with no errors. at 972 the computer wouldn't even post.
a couple things I'm thinking: on the HR-05 the little stability pad might prevent good contact with the chip. When I installed it, it seemed to be pretty secure.
maybe I need to remove my HSFs and re grease them?
Can someone diagnose my situation and offer some advice?
Whats going on?
