I just installed a storm block with swiftechs new radiator and a polorflo GPU block. after all the water was in and I started the comp the water is really cloudy and the temps are around 45 at start up. If you turn the computer off the cloudyness will go away but air is seen in the tubes. Now the obvious thing would be the cloudyness is caused by the air in the tubes so if this is true, will it go away and if it goes away will my temps go down? Thanks.
Setup MSI matx 939 board
4000+ san deigo
seagate 7200 250gb
2gb mushkin ram (1gbx2)
x800xl from msi
4000+ san deigo
seagate 7200 250gb
x800xl from msi
