High Tech LED Lighting
HardOCP News
[H] News
LED lighting has been all the rage in the computer world forever now but what about LED lighting around the house? What about LED lighting that looks like it is literally tearing through your wall?
Judging by this concept, designer Billy May almost surely has. His Torn Lighting is perfectly disguised on your wall while hiding it’s LED secrets from view. The result is the rather impressive illusion sure to leave your guests bemused, provided you paint it to match your walls of course.
I could see it in an ultra-modern house. Kinda cool, but not really my taste.
so do they mold the wall so it sticks out like that, and the light adds to the shadow??
They have this type of advanced LED lightning at some show house around here... I don't know where it moved to because it's no longer there. Basically it was a house made up fully of LED technologies (lights, walls, decorations, etc).
we have about 40 LEDs ranging from sizes ran through out our house that run off of a 12v battery in the garage, just turn them on when it gets dark and it provides enough lite to see through the house without turning on lights!
keeps the electric bill down too.
all the lights run to a switch box that has a wall plug in the bottom, we used an old 100ft extension cord to plug into that, then ran it out to the car battery and wired it onto the post! works a charm and the battery only needs charged once every 3 weeks or so (its a used battery too!)
Light bulbs just went off in my head. I just moved to AZ and being alittle greener with the cost of electricity down here is definitely on my mind.
How'd you wire it up inside the house?
A bunch of 24awg wire, its held up with staples and wrapped around the broken ceiling fan in the kitchen, then the LED's are pointed where you want them :)
the wire was the most expensive part of the whole thing...the LEDS arnt that expensive just the wire is.
all the wires run from the switch box that has 6 micro switches...everything but the LEDS, and extension cable came from radio shack, including a project box that houses a volt meter for the battery, wall socket, and the switches :)
You definitly want to skip compact flourescents and go straight to LEDs. They cost more but use way way less juice and last much longer.
If the industry ever gets around to making leds with integral heatsinks specifically for lighting purposes, the lightbulb will be a thing of the past. Right now they are just jury-rigged standard LEDs being used. The killer for LEDs is heat, which limits lifespan. But properly cooled an LED should last longer than LED's have existed to date.
http://www.besthongkong.com/
Thats where my dad gets all of his LEDs from, there in hong kong, but the shipping takes about a week/1.5 weeks to get to kentucky. so its not all that bad, its really good when your ordering 100+ leds, and they have the RBGs too, and pre wired 12v ones
(i in no way and affiliated with that site, i just know thats where my dad gets his leds from :) )
LEDs are the wave of future... Anyways, we're replacing all of our T8 ballasts and everything here. And hopefully using spots for our show room that are all computer controlled by occupancy.
Wow, that is really really impressive, nice work.
led accent lighting is great. will definitely be in my next home, and its not for the 'modern' homes only... its actually very affordable if you diy
