High stock temps?
keyboard12
Hey there, just built a machine with an PII X4 965 BE and the temps in BIOS with the stock cooler is 53 degrees. That seems a tad high, just wanted to get verification on that.
Once you run the aforementioned programs...would love to see what your temps are.
What HSF/thermal paste are you running with this setup?
Speedfan shows 45/46 degrees, 65 under load (prime95). The RAM however is REALLY hot when it isn't even doing anything, one stick is hotter than the other.
what is your voltage set to in the BIOS for both the CPU and the RAM??? If you have things set on 'auto', your CPU might be getting too much juice!
