High Quality audio SN25P question
Treyshadow
On the SN25P Via Vinyl sound card, you can enable High Quality 2 channel audio, and it is a definate improvement over the default audio. When enabled it uses the 7&8 channel connector on the back of the shuttle for audio. Is there a way to move the internal connectors for the front headphone jack to be on the 7&8 channels so I can connect my headphones to the front of the case using channels 7&8 in high quality rather than connecting them to the rear port?
I hope that this makes sense.
TiA
