High pitch/whining noise
xenium
So I built a setup consisting of these parts:
-PCP&C 610w silencer
-amd 7750 (cooler from bestbuy, not great but better than the stock one)
-2x1gb ocz gold ddr800
-ASUS M3A78-CM
-640gb wd hard drive
-260 gtx (192 core) msi
So, it worked fine for a couple days and I even overclocked the 7750 for a bit and it was running fine. So I shut it off, when to families house for christmas and when I got back I noticed it was making a god awful noise. Very high pitched, but not very audible. Still enough that gave me a headache :mad:
Now, it only happens when vista loads up about half way through the scroll bar thing. In the bios or the first half of loading vista, it doesn't do it but it.Also, it is only there at idle. If I put a load on the cpu it goes away instantly :confused:
I've tried it with cool and quite both enabled and disabled and neither helped.
It's not the 260gtx because I took it out and it was still there, and it's not the hard drive (I thought it was originally) so if anybody has any ideas, Im all ears.
I take it that none of the case fans are making this noise as well?
Can you find out which particular CPU cooler you have? I ask because I don't know whether it's a common problem (with the particular cooler) or a unique occurrence.
Could be coil whine form the PCP&C 610w PSU.
An Ultra V-Series 350w that I use as a spare has a bit of coil whine until you stress it under load, which sounds very similar to what you're experiencing.
I stopped all the fans in my PC to make sure it wasn;t those and while they were off and everyting was dead silent, the noise was still there. My bet right now is the psu...
Well, its definately coming from the PSU. I used a paper towel tube to my ear and when I put it near the PSU I can hear it whining.
Man, first PCP&C psu Ive ever used and it starts to go within 6 months.... Time to RMA it I guess :(
It could be the caps on the mobod. I have a pcp 750 and it used to run an asrock matx p4 mobod and it would squel under oercolcking. The asus M3A78-CM is not all solid state caps and regardless if it was or not, it can make high pitched electromagnetic noise similar to the noise from the back of a crt tv. You may need to rma your mobod. My pcp 610 doesn't make a sound other than the fan in my 9950be system. Capacitor selection sucks some times.
It's definately the PSU. Again, I took a paper towel roll and listened for where it was loudest and it was right at the back of the psu. Pointing the roll anywhere on the mobo just gave me noise from the cpu fan.
Hopefully I can get a quick RMA from pcp&c :)
