High-pitch noise when I scroll webpages
eXacto
I recently started hearing this whine, extremely high pitched and just loud enough to bother me. It seems like it's constant now, but when I scroll webpages using the mouse wheel or even do something like hold down the backspace key to delete text, the noise intensifies.
:wtf: is going on here? Am I about to blow a cap or something?
I *think* the noise is coming from the powersupply but I can't be 100% sure. It's a Sparkle PS so I thought it would be good, but I've had other strange noise problems with it before.
I can almost guarantee that its your monitor. mine does the exact same thing and one of my TV's also does it. It has too do with the colours being shown on the screen I think.
That doesn't mean you should rule out your PSU though, if you have had problems with it in the past it might be making the noise. A good way to check would be to hook it up to a different PC and see if it does the same thing.
Hm, it sounds like your problem only occurs when the processor is under load.
Perhaps its some software or a bios setting that automatically adjusts your Heat Sink fan depending on the heat. And when the processor is under 100% load, the fan kicks up into high gear and makes the sound.
But obviously, if the sound is comming from the monitor, and not the computer tower............... then that's not it ^_^.
I have never heard of a monitor doing that.......... odd.
I recommend trying to do something to make your processor go to 100% activity, and see if it makes the sound. Heck, you can even turn off the monitor to make sure ^_^.
I know some people use a program called pifast http://numbers.computation.free.fr/Constants/PiProgram/pifast.html
If that still makes the noise, its probably a fan with an auto RPM feature. (maybe case fans, maybe PSU fan, maybe heat sink........ or maybe more then just one).
~Hope this helps, and keep us posted
I can guarantee it's not coming from the monitor. As I sit right here in front of the monitor I can tell the sound is coming from the left, where my tower is.
Also, when I do a stress test on my computer, the noise does not occur. I was beginning to think it might have something to do with the load placed on the cpu by scrolling webpages, but apparently it's not.
When the sound starts trying turning off your monitor then, as besides that I would open up my case and see if its possibly one of the CD drives or even possibly a HD
One of these is probably oscillating on your motherboard. You can put your finger on it while it's making the noise and it should stop. Once you know which one is oscillating, put some hot glue on it.
I've recently read about others having the same issue. Mercurien is probably right and its worth a shot.
I've heard of this issue with the first batch of the nVidia FX series cards that came out.
If you in fact have an nVidia card, make sure you have the latest drivers for the video card and the latest INF drivers for your monitor.
my fx does it i have heared rumors that its the voltage regulators... but loading mbm5 makes my motherboard do it
i only hear the scrolling thing if my room is silent and i have my case open
i thought maybe it was a ground/power problem between the mouse and the mobo,
intermittent enough , not always making the whine .
i had it once on my rig , seems to me i upgraded the mouse and cpu/mobo and haven't heard it since .
/shrug
tools>internet options>advanced tab. Under browse make sure use smooth scrolling is unchecked.
If that doesn't work, try what Mercurien said.
The PSU is the problem, but I cannot make it stop the noise. I opened it up and pushed on all the parts (with a plastic pen) to make sure they were connected well and stable, but it didn't help. I listened very closely to the PSU while I rolled the scroll wheel and I could hear the buzzing coming right from it, but I can't pinpoint exactly where.
edit: I checked all of the inductors on the mobo too and they seem to be fine.
Some of our school computers make the same noise (they are Celeron 1000's :rolleyes:, 256MB RAM). I thought they came from the speakers that are mounted in the 5.25" bay. It also makes that noise when loading programs, so it could really be any electrical component expanding and contracting quick enough to make that high frequency noise.
Make sure your 120V/240V switch is on the correct setting.... im not sure if that would cause the problem, but it seems logical.
it wouldnt boot or it would blow up if it was wrong depending on location
lol!!34
Dood, it would've blown up or ceased to work if it was anywhere but 120V...
-J.
ChingChang said:
hey... he was just trying to help.
He's right. I just *try* and help.
I never tried setting a PSU to 240v instead of 120v ... so i would'nt know. But the concept made sense (if its set to 240v, and its only getting 120v, the step-down transformer might not be working correctly, thus making noises.... you know, odd stuff like that).
I live and learn.
