Not fixable.
That's just the noise that some drive models make. All hard drives are not the same (or even close) when it comes to idle noise.
Thanks for replys, I should have been more precise.
I have had this sata drive for 1.5 years. The high pitch noise has developed recently. It is intermittent. Sometimes goes for minutes, sometimes hours, sometimes not at all for days.
Stll though, not fixable? Will mess up the drive simply by opening and maybe trying to blow around with compressed air?
Thanks for reply, Are you saying that sound could be an indicator of potential failure?
Back to topic, if it is a bearing can in be cleaned, fixed or replaced?
