Hello,
I'm trying to debug a latency / bandwidth issue with 2 servers ( DELL 860 ) connected by infiniband.
Servers use 10Gb cards connected on a MTS2400, here are the result for bw and latency:
Are those values 'normal'? I was hoping to get more bw and less latency :/
I'm using CentOS 6.4 with ib_ipoib driver, it's using stock settings.
Thank you,
Code:
[ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams
[ 3] 0.0-600.0 sec 374 GBytes 5.35 Gbits/sec 0.002 ms 433015/273309755 (0.16%)
Code:
[root@node-002 network-scripts]# ib_write_bw 10.0.0.1
RDMA_Write BW Test
Number of qps : 1
Connection type : RC
TX depth : 300
CQ Moderation : 50
Mtu : 2048B
Link type : IB
Max inline data : 0B
rdma_cm QPs : OFF
Data ex. method : Ethernet
local address: LID 0x05 QPN 0x70407 PSN 0x7dd459 RKey 0x340041 VAddr 0x007fbc2f49a000
remote address: LID 0x01 QPN 0x60407 PSN 0x7bc639 RKey 0xa00041 VAddr 0x007f281be84000
#bytes #iterations BW peak[MB/sec] BW average[MB/sec]
65536 5000 935.36 935.34
Code:
[root@node-002 network-scripts]# ib_send_lat 10.0.0.1
Send Latency Test
Number of qps : 1
TX depth : 50
CQ Moderation : 50
Mtu : 2048B
Link type : IB
rdma_cm QPs : OFF
local address: LID 0x05 QPN 0x80407 PSN 000000
remote address: LID 0x01 QPN 0x70407 PSN 000000
#bytes #iterations t_min[usec] t_max[usec] t_typical[usec]
2 1000 5.52 32.15 5.62
Code:
[root@node-002 network-scripts]# ping -c 5 10.0.0.1
PING 10.0.0.1 (10.0.0.1) 56(84) bytes of data.
64 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=0.179 ms
64 bytes from 10.0.0.1: icmp_seq=2 ttl=64 time=0.247 ms
64 bytes from 10.0.0.1: icmp_seq=3 ttl=64 time=0.246 ms
64 bytes from 10.0.0.1: icmp_seq=4 ttl=64 time=0.247 ms
64 bytes from 10.0.0.1: icmp_seq=5 ttl=64 time=0.250 ms
Code:
[root@node-001 network-scripts]# iblinkinfo
CA: node-002 mthca0:
0x0002c90200201d21 5 1[ ] ==( 4X 2.5 Gbps Active/ LinkUp)==> 3 2[ ] "MT47396 Infiniscale-III Mellanox Technologies" ( )
Switch: 0x0002c9010c57f7f0 MT47396 Infiniscale-III Mellanox Technologies:
3 1[ ] ==( 4X 2.5 Gbps Active/ LinkUp)==> 1 1[ ] "node-001 mthca0" ( )
3 2[ ] ==( 4X 2.5 Gbps Active/ LinkUp)==> 5 1[ ] "node-002 mthca0" ( )
3 3[ ] ==( Down/ Polling)==> [ ] "" ( )
3 4[ ] ==( Down/ Polling)==> [ ] "" ( )
3 5[ ] ==( Down/ Polling)==> [ ] "" ( )
3 6[ ] ==( Down/ Polling)==> [ ] "" ( )
3 7[ ] ==( Down/ Polling)==> [ ] "" ( )
3 8[ ] ==( Down/ Polling)==> [ ] "" ( )
3 9[ ] ==( Down/ Polling)==> [ ] "" ( )
3 10[ ] ==( Down/ Polling)==> [ ] "" ( )
3 11[ ] ==( Down/ Polling)==> [ ] "" ( )
3 12[ ] ==( Down/ Polling)==> [ ] "" ( )
3 13[ ] ==( Down/ Polling)==> [ ] "" ( )
3 14[ ] ==( Down/ Polling)==> [ ] "" ( )
3 15[ ] ==( Down/ Polling)==> [ ] "" ( )
3 16[ ] ==( Down/ Polling)==> [ ] "" ( )
3 17[ ] ==( Down/ Polling)==> [ ] "" ( )
3 18[ ] ==( Down/ Polling)==> [ ] "" ( )
3 19[ ] ==( Down/ Polling)==> [ ] "" ( )
3 20[ ] ==( Down/ Polling)==> [ ] "" ( )
3 21[ ] ==( Down/ Polling)==> [ ] "" ( )
3 22[ ] ==( Down/ Polling)==> [ ] "" ( )
3 23[ ] ==( Down/ Polling)==> [ ] "" ( )
3 24[ ] ==( Down/ Polling)==> [ ] "" ( )
CA: node-001 mthca0:
0x0002c90200008879 1 1[ ] ==( 4X 2.5 Gbps Active/ LinkUp)==> 3 1[ ] "MT47396 Infiniscale-III Mellanox Technologies" ( )
Thank you,
