I just got a used Q9450 today and I am having some trouble already. I am getting idle temps of about 45-50C across the cores according to real temp. This is on all stock settings, no OC. I am using an Arctic Cooling Freezer 7 pro, which should be plenty to keep it cool at stock settings. Voltage is at 1.2v in bios, 1.152 in CPU-Z. I have already replaced cooler/thermal paste about 4 times, including once outside the case and i keep getting the same results. I followed the instructions for the arctic silver and c2q. When I load up prime95, temps go up to about 63/64C after just a minute or two. Why are my temps so high?
