high GPU temp
My top card goes towards 80c wery quickly in IDLE in windows.
I put finger on waterblock and it burns my finger so the block in properly installed.
It has to be airpocket problem right?
When I tilt the PC on side so that the motherboard is against table I can see air go out of the gpu's into the cpu block and to reservoir.
However seems like anytime I do this air seems to go from res to pump and then finally back to the gpu block?!
I'm now running just the pump at level 5 and hoping for best in bleeding air.
