High Flow Next In USA
Leakshield is interesting, but a bit pricey in my opinion. If you build your loop correctly the odds of a failure are pretty low. I could see the use more if your water cooling loop is getting old or you use pure water for maximum performance. I do like the High Flow next, I think it's a good value, but they really need to reconsider charging for software updates on it.
