High flow meter for less than $7 + shipping
I think a possible and useful improvement on the design of this flow meter would be to use a magnetic switch, similar to what people use for a door break-in alarm, on the outside of the flow metering column, and make the inner indicator ring magnetic. This way, the switch will be open when the indicator ring is not at the same level as the magnetic switch outside, which you set at the desired flow, telling you that the flow is below a certain value. On the other hand, under right conditions where the flow corresponds to the value you set by adjusting the magnetic switch, the indicator ring and the magnetic switch will be at the same position, closing a switch and possibly lighting a green LED, indicating no problem with the flow.
I don't even want to think about how much of a pressure drop this causes. :(
QUOTE:
"The Flow Meter uses variable area technology, in which the velocity of the water forces the Float Indicator to shift position - up or down - increasing or decreasing the size of the opening to allow water to flow past. As such, the water flow must move in the same direction as the arrow on the base of the Flow Meter."
I would say next to nothing...
But if your running a resivour, or even a T line, put it right before your pump/res and your fine, right?
edit: and excellent work using the green font.
Yeah the green font almost gets rid of that annoying word advertising. ;)
From my experience it doesn't matter where you put a flow meter as you are only looking for average flow anyway.
Now that sounds like a great idea! At the very least you could impregnate the plastic bob with some kind of small magnetic material. The outside ring could be easily setup with existing switches.
Maybe, but the Laing D5 looks pretty hideous to me as well. Sounds like a marriage made in heaven, heh?
Yeah, I always wondered why the main support nut that connects the motor to the inlet/outlet plastic assembly looks like it was taken from a dump truck... Those huge, menacing ridges...
Bahaha, yes, the D5 is a three headed Cerberus... But it pumps long and hard, so what can I do :eek:. I hide mine in the bottom of my case.
Looks very interesting, and I really don't find it that bad looking - and nothing a few minutes of modding can't soften out anyway. Then again, I don't find D5's unattractive at all - not sexy, but I wouldn't try to hide one from sight.
Back on the flow meter, not very precise, so I don't think it would be too useful, unless you wanted to use it as a flow monitor or couldn't figure out how to use the System Flowrate Estimator Spreadsheet.
