The 30" ACD is currently the largest single panel display for computer applications that is commonly available. Anything larger and you will only drop in resolution and lose real estate even if the total viewing area is larger. You have to decide what is more important to you, maximum screen size or native resolution.
Plasmas are typically not good for computer applications. Other members might give you a more technical reply than I, but suffice to say that screen burn is a major concern. Very limited resolution availability is another. And they're usually more bulky than similarly sized LCDs, although this may have changed recently. Power consumption might be another.
What resolution range are you looking for? What is the intended purpose for the display?
