I have revised the system a lot but I know there are probably some problems and better choices I could make which is why I am asking for your advice. I appreciate any advice even if it is a small detail.
Monitor--Dell UltraSharp 2405FPW 24-inch Wide Aspect Flat Panel LCD Monitor-$959
http://accessories.us.dell.com/sna/productdetail.aspx?sku=320-4221&cs=19&c=us&l=en
~~~Anyone have a coupon for this?
Motherboard--DFI LANPARTY nF4 SLI-DR ATX AMD Motherboard-$200
http://www.newegg.com/Product/Product.asp?item=N82E16813136151
CPU--AMD Athlon 64 FX57 San Diego 1GHz FSB 1MB L2 Cache Socket 939 Processor - OEM -$1031
http://www.newegg.com/Product/Product.asp?Item=N82E16819103559
~~~Is the XP90c the best heatsink to get with this cpu?
Video Card(2)--XFX PVT70FUNF7 Geforce 7800GTX 256MB 256-bit GDDR3 VIVO PCI Express x16 Video Card with 450MHz Core and 1250MHz Memory-$1000
http://www.newegg.com/Product/Product.asp?Item=N82E16814150100
Case-- Thermaltake Armor VA8000SWA Silver Computer Case With Side Panel Window-$175
http://www.newegg.com/Product/Product.asp?Item=N82E16811133155
Floppy Disk--SONY Black Internal Floppy Drive Model MPF920 Black OEM--$11
http://www.newegg.com/Product/Product.asp?item=N82E16821103116
Memory(2x1gb)-- OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Platinum System Memory-$270
http://www.newegg.com/Product/Product.asp?Item=N82E16820227210
PSU--PC Power & Cooling 510 SLI-PFC ATX12V 510W Power Supply 90 - 264V UL/ ULC/ TUV/ CE -$220
http://www.newegg.com/Product/Product.asp?Item=N82E16817703001
HD--Western Digital Raptor WD740GD 74GB Serial ATA 10,000RPM Hard Drive w/8MB Buffer and Serial ATA Cable Bundle -$188
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101222-316604
HD-- Maxtor Maxline III 7L250S0 250GB Serial ATA 7200RPM Hard Drive w/16MB Buffer-$127
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100718-6
~~~Is this the type of Maxtor HD that I should get? I could settle for 200 gb also.
Media--PLEXTOR Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 4X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE DVD Burner-$93
http://www.newegg.com/Product/Produ...357&ATT=CD+DVD+Burners+RW+Dr&CMP=OTC-d3alt1me
Cooling--Thermalright XP-90C Copper Heatsink-$45
http://www.jab-tech.com/customer/product.php?productid=2836&cat=169&page=1
~~~Which fan should I choose from? How often do you have to clean the surface with this ceramic stuff?
MouseMX518-$40
http://www.newegg.com/Product/Product.asp?item=N82E16826104178
Keyboard--Saitek Black Wired Eclipse Keyboard-$47
http://www.newegg.com/Product/Product.asp?item=N82E16823175103
Mouse Pad--Banshee Pad-$40
http://www.bansheepad.com/cart.php?target=product&product_id=16133&category_id=248
Headphones--Sennheiser HD555 Stereo Headphones-$150
http://www.newegg.com/Product/Product.asp?Item=N82E16826106392
Mircrophone--Logitech 980240-0403 Black 3.5mm Connector Desktop Microphone-$9
http://www.newegg.com/Product/Product.asp?Item=N82E16836111602
OS--Microsoft Windows XP Professional With Service Pack 2 - OEM-$147
http://www.newegg.com/Product/Product.asp?Item=N82E16837102153
Some questions I have is whether or not I will need to buy a NIC card(not sure if it will come with another part) and which non wireless router I should get. I would like one that transfers data the fastest without losing any of it. Another question I have is whether I am missing something. I put down everything I plan on buying so if you see something that I will need please let me know. Thank you.
MouseMX518-$40
