Building a workstation for software development. I need something with a lot of bandwidth to the graphics card (to drive the massive resolution of the monitor at a high depth).
I also plan to use vmware workstation a lot so virtualization and a lot of horsepower will be very important.
Running both drive sets raid 1.
SAMSUNG SyncMaster 305T Black 30"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001098
$1299.99
Antec P182 Gun Metal Black 0.8mm cold rolled steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129025
$169.99
SAMSUNG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X
CD-ROM 2MB Cache SATA DVD Burner With LightScribe Technology - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151141
$36.99
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136012
$194.99 x 2
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3750640AS 750GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148134
209.99 x 2
Intel Core 2 Duo E6850 Conroe 3.0GHz 4M shared L2 Cache LGA 775 Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115028&Tpk=e6850
$329.99
GIGABYTE GA-P35T-DQ6 LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128055
$239.99
Things I still need.
DDR3 1333 4gigs of ram (preferably 2 sticks of 2gig)
can't find! need to find some.
Also, haven't decided on the graphics card yet. Need something that can handle windows vista not just stright up, but in vmware as well running concurrently.
lastly, I need to figure out how much power I'm going ot need and what type of power supply. I'm guessing I will need at least 700 watts.
$1299.99
$169.99
$36.99
$194.99 x 2
209.99 x 2
$329.99
$239.99
