High DPI Displays
these appear to use OEM'd Chromebook displays. too bad the project doesn't integrate the multitouch.
You guys should take existing displays (say, 1440p ones) and create some monitors that don't use scaling chips. I would buy a delay-free 2560x1440 PLS that doesn't use PWM.
Neat-o. It's very similar to the Adafruit display, which is basically an Ipad display with the same display board, but a little bigger.
Eh, I'm in for one. It's a convenient enough size, and I've wanted to own a high-DPI display since... sixth grade?
