High Density SSD's
Discussion in 'SSDs & Data Storage' started by fullvietFX, Feb 3, 2019.
  1. fullvietFX
    fullvietFX [H]ard|Gawd
    1,663
    Sep 1, 2004
    Is there any news on whether we'll be getting 6TB/8TB SSD's this year? None of these HTPC cases seem to be coming out with an option to mount 3.5" drives anymore.
  2. Farva
    Farva [H]ard as it Gets
    35,176
    Feb 3, 2004
  3. Skillz
    Skillz [H]ard DCOTY 2017
    21,609
    Aug 14, 2004
    Who keeps the media stored on the HTPC these days anyway? I have a 500GB SSD in my HTPC, but all my media (15TB+) is stored on my NAS and streamed to my HTPC using Plex.
    Orddie likes this.
  4. fullvietFX
    1,663
    Sep 1, 2004
    I like to keep it all in once box, and those cases that allow 3.5" are too large for me. I've never used a NAS before either, maybe it's time I look into one.
  5. Skillz
    21,609
    Aug 14, 2004
    Well my NAS is technically just a computer in a Fractal Define R5 with a 10c/20t Xeon and 6 3TB drives, 1 8TB drive and a 500GB SSD. Running Windows w/ Plex Media Server running. My HTPC is a Fractal Node 605 w/ Sandy Bridge quad core and 500GB SSD.
    The benefit of having my media stored on a dedicated computer is the fact that I can upgrade and expand the storage easily and using Plex I can stream the media to pretty much anything (phones, computers, roku, firestick, etc..)
  6. mwroobel
    mwroobel [H]ardness Supreme
    4,867
    Jul 24, 2008
    Well, since you are looking for 6/8TB SSD's, then money is probably not a problem. Here is a great deal on a Samsung PM1643 30TB SSD, just under 12K US$. For an enterprise SAS drive like that, it is a steal (Seriously!)
    Orddie likes this.
  7. fullvietFX
    1,663
    Sep 1, 2004
    That's definitely over budget. I want to pay absolute $1500 max for one drive.
  8. Blue Fox
    Blue Fox [H]ardForum Junkie
    11,648
    Jun 9, 2004
  9. Machupo
    Machupo Gravity Tester
    4,732
    Nov 14, 2004
    How much logical space do you need for your media, how much physical space do you have in the case, and how many SATA plugs does your mobo have?
    Since the Samsung QVO 4TB drives are basically 1.8" boards, you could shuck and mount 4-6 of them in a 3.5" mounting bracket if density was your goal and money did not matter.
  10. Abula
    Abula Gawd
    928
    Oct 29, 2004
    I would go the nas route, i would suggest to look into something like Synology DiskStation DS218+ and 2x 8TB hdds and set them up in raid 1, and place it where you have a wired connection to your router/switch, setup the share folders.
    If you dont want to go the nas route, and you have 2 sata ports available, raid 0 2x Samsung QVO 4TB.
  11. fullvietFX
    1,663
    Sep 1, 2004
    I want to avoid RAID. I have one drive for television/music and one drive for movies. I think having a NAS would be waste since nobody views media on my gaming machines. I currently have two 3.5" that are 4TB but they are running out of space and I want to move my HTPC into a smaller case.
  12. fullvietFX
    1,663
    Sep 1, 2004
  13. Machupo
    4,732
    Nov 14, 2004
    I'm sorry -- this sounds like "I'd like to avoid data redundancy and keep all of my eggs in one basket".
    You can buy 3.5" hdd's that are 12TB, why not just replace your 4TB drives with these?
    Alternately, you can buy 5TB laptop (2.5") hdds.
    Why spend the extra scratch on ssds?
    IdiotInCharge likes this.
  14. Comixbooks
    Comixbooks Ignore Me
    12,173
    Jun 7, 2008
    I want to own large capacity solid SSD drives but even 2TB drives are expensive would really like 4TB drives but I would want two of them. These HGST helium drives make a popcorn sound driving me nuts already.
    I do own 1TB SSD drives but I would have to uninstall a bunch of games that I haven't had time to get around to.l
  15. Verge
    Verge [H]ardness Supreme
    6,026
    May 27, 2001
    Archaeologists ?
    Relics from an ancient time.
  16. fullvietFX
    1,663
    Sep 1, 2004
    Just seems unnecessary to have two machines. My HTPC never turns off.
    ZeqOBpf6 likes this.
  17. Verge
    6,026
    May 27, 2001
    Why have an htpc?
  18. fullvietFX
    1,663
    Sep 1, 2004
    I use it as a gaming/web-browsing/media rig in the living room hooked up to the TV.
  19. fullvietFX
    1,663
    Sep 1, 2004
    Do you need that much horsepower? 10c/20t seems like overkill, still awesome though.
  20. Skillz
    21,609
    Aug 14, 2004
    Yes for the PMS server. I also use the idle cores for running BOINC projects when they're not in use. PMS transcoding can really beat down a CPU.
  21. Blue Fox
    11,648
    Jun 9, 2004
    You really are better off with a simple NAS. A single bay Synology NAS will use ~10W when the disk is being accessed and ~5W idle (or ~$7 annually if idle 50% of the time). For media streaming, there is zero difference between a hard drive and SSD, so, if you get an 8TB drive + a Synology DS119j, you are looking at ~$300. Nearly $1000 less than the SSD. It's just not worth getting for what you'd be doing with it. Even if you got a 14TB drive, it would still be considerably cheaper.
    Alternatively a lot of consumer routers have NAS functionality. If yours does, just plug in a USB drive to that. 8TB externals can be had for ~$150.
  22. fullvietFX
    1,663
    Sep 1, 2004
    Awesome, thanks man. I'll probably save myself a ton of money and go NAS route then. Only annoying thing is having music files on NAS might be annoying since it takes a little bit of time to access. Maybe I'll store all my music locally.
  23. Skillz
    21,609
    Aug 14, 2004
  24. Blue Fox
    11,648
    Jun 9, 2004
    I doubt you will notice any delay streaming music either, but that's up to you. 2.5" hard drives are cheap and can be had up to 5TB capacities.
  25. ciscokid454
    ciscokid454 2[H]4U
    2,355
    Oct 26, 2000
    You cant go wrong with a small/decent nas.
    4-5 bay for some redundancy
  26. fullvietFX
    1,663
    Sep 1, 2004
    Everyone running their NAS with RAID1?
  27. Machupo
    4,732
    Nov 14, 2004
    I have six disks of parity in my 30 drive array (3 vdevs each at Z2 -- zfs is a bit different than RAID).
    RAID 1 is costly in terms of space but provides insurance against 1x drive failure and a depreciating return on additional drive failures based upon the size of the array. I wouldn't use it, personally, but know some people who have without issue.
  28. rsquared
    rsquared Limp Gawd
    473
    Jul 5, 2007
    I have a two-bay NAS in RAID 1 for backups and archival, and a four-bay NAS in RAID 5 as media storage and streamer. Not having my backups guarded against HD failure would be kind of self-defeating. If the media storage failed I wouldn't lose data, I could re-rip everything from my DVDs and Blu-Rays, but I would lose a lot of time to do all that over again.
  29. Machupo
    4,732
    Nov 14, 2004
    I just grabbed 4x WD Blue 2TB m.2 drives and a 4-way adapter (one of those startech inventions). Thinking about putting 3x of these setups into a 1U short-depth case and consolidating my NAS down a bit (I really have no use for the 100TB current iteration ;p); that would give me 10x drives in Z2 and mirrored os drives all with the onboard sata ports (no hba needed).
    Lol, if this works out you may see 30x 4TB seagate spinners show up on the FS/FT forum :D
  30. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    8,197
    Jun 13, 2003
    If you have two drives, sure. Even if you have four and you need performance (a striped mirror). But you don't need that for media.
    But seriously, just grab two larger spinners and toss those in a mirror in your HTPC and you're basically done.
  31. GamerAddict76
    GamerAddict76 n00b
    6
    Jan 23, 2019
    I have a Qnap TS-873 with 8 gigs of ram and a GTX1030 for hardware transcoding 4k and 8x8tb drives running Raid 5. Absolutely love it. I can't wait till large capacity SSDs become realistic and more cost effective.
  32. fullvietFX
    1,663
    Sep 1, 2004
    This encodes the video before streaming it to the display device I'm assuming?
  33. GamerAddict76
    GamerAddict76 n00b
    6
    Jan 23, 2019
    Correct
  34. Abula
    Abula Gawd
    928
    Oct 29, 2004
    IIRC the 1030 dont have any encoders, but maybe does have decoders, so you use the GT1030 to decode and CPU to transcode?
  35. fullvietFX
    1,663
    Sep 1, 2004
    Encode/decode/transcode I'm not sure what word to use but I meant that basically the NAS does all the hard-work before sending it off.
  36. Machupo
    4,732
    Nov 14, 2004
    That depends on the software you use. For example: Plex will either direct play or transcode as needed based upon the source (file) resolution and other components and the display resolution. If necessary, all of that work is done by the NAS.
  37. GamerAddict76
    GamerAddict76 n00b
    6
    Jan 23, 2019
    The NAS can transcode without the additional card, or use the card to transcode 4k content.
