Feb 17, 2007 #1 3 3erious n00b Joined Jan 27, 2007 Messages 47 I have a x2 3800 but i am getting high usage(48%) on the first core and 90% on the second core. It is 99% on system idle process but 0% on all other processes. and
Feb 17, 2007 #2 w1retap [H]F Junkie 2FA Joined Jul 17, 2006 Messages 14,525 Do a thorough spyware and virus scan?
Feb 18, 2007 #3 F Flawles Weaksauce Joined Dec 12, 2004 Messages 101 yea run a virus scan and spyware scan also try running CCleaner, or installing dual core drivers?
Feb 22, 2007 #4 3 3erious n00b Joined Jan 27, 2007 Messages 47 Hi, I found out that my audigy 2 card is causing the problem. If i view process manager it says the hardware interrupts are using the cpu usage. Can you tell me what effect this has on games and its frame rates if it using 48% all the time. 3erious
