Raymond Garrett
- Jan 13, 2017
First my system specs:
Core I7 2600k running at stock 3800Mhz with Speedstep enabled
ASUS P8Z68-V PRO/GEN3
16 GB DDR3 Kingston RAM running at 1600Mhz using XMP profile
ASUS GTX 970 Strix
Corsair Carbide Series 200R Case
Coolermaster Hyper 212 EVO CPU cooler
2 120mm Intake fans in the front
1 120mm exhaust fan in the back
1 140mm exhaust fan on top
There are also 2 SSDs and 3 Hard drives in the case.
There are no other cards installed and all cables are neatly run in the back of the case.
My CPU temps at idle as shown by HWMonitor fluctuare between 40 and 43 degrees.
When running IntelBurnTest at maximum stress level, my CPU temps hit around 81 degrees.
I tried overclocking my CPU to 4.5Ghz. At those speeds, IntelBurnTest hit 95 degrees within a matter of minutes.
The ambient room temperature in my home office where my PC is located is currently 28 degrees.
I have removed and re-seated the CPU cooler several times and have confirmed that it is installed correctly.
Even though my overclock is stable and I do not experience and system crashes, the high CPU temperatures I am getting are preventing me from running my CPU at anything except stock speeds.
I have 3 other PCs here in the office. My wife's PC and 2 servers. All are exhibiting what appear to be higher than average idle temps. I have a feeling this is due to the high ambient temperature in the room.
Is there anything I am missing here? Everyone keeps telling me I should have no problem overclocking my CPU to 4.5Ghz, but this does not appear to be possible because the temps are so high.
ASUS GTX 970 Strix
