High CFM Fan selection for a mod...........
chrisyak
I need some help picking 2 fans for a mod i am doing on my pc,i wanted to go with Panalfo's but their is a size problem they are 120x120x38mm and i need 120x120x25mm and they don't make 120x120x25mm.:(
So i need help with selection of a new fan that does come in 120x120x25mm size that has very high CFM rate but has a decent db rate aswell any suggestions will be helpfull.
From what i have heard the thermaltake's have a excessive amount of bearing noise not that i am overly concerned with noise.......Maby some Delta's or Sunon's????
no such thing as a small delta afaik, sunon maybe, thermaltake fans from what my friend says are pretty darn quiet, at least those
not look for a small version just one 25mm thick......alot of fans are only 25mm thick but alot of the high cfm 120mm fans are 38mm
actually i was able to mod it so normal panaflo 120x120x38 would fit...........Now i just need 2xPanaflo 120mm M1A anyone have some for sale?
