avatar_of_might
- Nov 11, 2002
ok i just installed a athlon 64 3200+ on a MSI K8N Neo and the temp monitor says its running at avg 62 deg C! now im using stock cooling which looks a LOT better than what came with the XP processors so i thought it should work. is it the stock cooling? are these average temps for the new processors or will the temp go down as the machine gets burned in more? or should i use a new cooler? thanks in advance.
