I used black electrical tape when I put my Antec 900 together for the first time. After having to take it apart a few times, the electrical tape ended up leaving a sticky residue behind, which gets funky. I ended up cleaning the residue with rubbing alcohol, and after I had my case powder coated, I ended up using these:
My local Home Depot carried big packs of them, for cheap. They were in the electrical dept.
This will sound stupid but how do you use those things?
