qdemn7 said:Lots of good ideas here.
DOH!Lazy_Moron said:I think he is talking about the wires on his desk, like monitor power cords, mouse and keyboard cords.
Check out Cable Organizer.com If you can't find something here, you're SOL.Yaka said:yep i am, i i tried using cabel ties for all the aire bar the keyboard an mouse ones but it still looks messy
krotch said:Fire. Fire can hide everything, including incriminating evidence.
Yaka said:anyone got any tips on hdinge cables? i got a glass desk with a fair bit of kit on like pcs, monitors amps and consoles all there is alot of wires on show and need advice on hiding them
ZigZagZeppelin said:My better half took the time to actually wind & twist all the wires in her office into one huge thick wire & then I cable tied it in 3 places. Looks better but not perfect.
What is the frame of your glass desk made of? If it's pipe, you could try and get some similar pipe to route the wires through. or PVC pipe, painted to match, & run along the back edge of the desk with well placed openings for the wires where they come out to the individual components. This way, if you need to pull the mouse or keyboard wire out for some reason, as long as you got pipe that's slightly oversized, you should be able to just pull it right out. (HINT: tie a piece of string to one end before you pull it out so you can retie the string & pull it back through the pipe later)Yaka said:anyone got any tips on hdinge cables? i got a glass desk with a fair bit of kit on like pcs, monitors amps and consoles all there is alot of wires on show and need advice on hiding them
