masterofcows
- Dec 12, 2005
hey guys. i was wondering if u guys can give me some tips on how i can clear up my case wit all the wires everywhere and i was also wondering if u guys can check if my watercooling set up is safe and workable.
i was also wondering how come i can only overclock my cpu to 235. it can go up to 239 max but is it not possible to go higher?
my ram is
Information SPD EEPROM (A2) :
Manufacturer : Corsair
Part Number : CMX1024-3200
Serial Number : Unspecified
Type : DDR-SDRAM PC3200 (200 MHz) - [DDR-400]
Size : 1024 MB (2 rows, 4 banks)
and i have a athlon X2 3800+, wit a 7800gtx, wit a a8n sli motherboard. i thought i could go higher wit the watercooling. maybe i did it wrong?
thx
my ram is
thx
