I live in a 3500 square ft house. We have Cox Internet and use their Netgear cable modem with built in Wifi. I have installed am access point using the main ssid on the second floor which consistently pulls 30 Mbps down and uploads right around 6-8 Mbps. The house was prewired with cat 5e and the AP is connected through that into the back of the cox router / modem.
Downstairs is a completely different story. The all in one PC in the kitchen connects via wifi and 90% of the time has low signal from the wireless but will connect.
Yesterday I bought a second router that is able to be configured as am access point like the one I have upstairs. I set it up, set the ssid to the one we use and now it won't even complete a speedtest. It gets stuck on the "connecting" part. Downloads are painfully slow. A 2mb file took 15 minutes. I installed a Netgear USB wireless n dongle and had the same results so that pretty much rules out the all in one pc's built in wifi going bad.
I'm going mad trying to fix this. At this point, moneynis no object. I just want the shit to work. What's going on here? What more info can I provide that will be helpful?
I'm case I forgot to mention, the cable modem is downstairs in the master bedroom closet.
