Here is my first system build...
vdubbia
parts are on the way.. let me know what else I should consider:
Lian Li PC65 case
C2D 6750
2Mb G.Skill PC6400 RAM
EVGA 8800GTS 320Mb
Earthwatts 500W 80Plus PSU
Abit IP35-E Mobo
320Gb Seagate SATA HDD
Just deciding on what OS to install... any suggestions? Would like to stick with XP or Vista, just not sure what OS will provide the best experience. How is Vista these days?
XP had its problems also and still does... So get vista and enjoy its sexiness. I suggest getting Cosair 520watt PSU.
Unfortunately 2 megabytes of RAM is going to have trouble pulling Windows 3.1, let alone XP or Vista :)
In all seriousness, Vista has matured greatly over the last 10 months, with the exception of Creative X-Fi drivers, which still have a ways to go. Assuming you have a copy of XP laying around somewhere, there's no harm in buying Vista now and trying it out. If you don't like it, you can always fall back to XP and put Vista on the shelf for when you're ready to try again.
Mark.
LOL. You're saying that with a Conroe 6750 and 2Mb of RAM Vista will be somewhat crippled? I am currently on 4Mb RAM in my P4 system (seeing 3.25) and figured that with the upgrade in processor I could live with the 1.25 reduction of visible RAM.
I can up to 4 if needed; but by all accounts 2Mb should certainly be adequate shouldn't it? Unless you can point me to benchmarks proving otherwise.
Do 32 and 64 bit versions ship in the OEM Vista boxes?
Um... no it's a joke. I'm sure you mean 2 gigabytes of RAM, not 2 megabytes of ram. Mb = megabyte. Gb or Gig = gigybate.
EDIT: You don't get both 32 or 64 bit editions with the OEM box, and with all things considered, you're probably better off with 4 gigs of RAM and Vista x64 then with 2 gigs of RAM and Vista 32. Remember that 32-bit windows can't see all 4 gigs of RAM due to memory mapping limits. It's not that two gigs of RAM isn't enough for Vista. It's just that DDR-2 RAM is particularly cheap right now, and Vista utilizes extra, not-currently-in-use RAM in much more effective ways than XP, so there's little reason not to go with four. I've also never really seen anyone justify an increase in processor power as a means to decrease RAM, unless its a cost issue. Still, always better to build systems with the same or more RAM then your previous rig, not less.
Mark.
Most definately. Sorry, couldn't resist after you didnt catch Mark's joke.
Oh, and just a technicality, but "B" is usually Bytes while "b" is usually bits. 1 Byte = 8 bits. Forgive me, I'm a sw engineer, lol.
oof! i'm an ID10T.
thanks for pointing out my typo (at least I was consistent! ;) ).. the comments make more sense now. lol.
I'll buck up and get the two extra sticks to make the system 4GB.
With that being said, is Vista64 the direction I should be headed in with the system specs I've described? Any Googleing I've done re Vista64 only brings up articles from mid-2006 and I know things have probably changed a lot since then. Are driver issues pretty much resolved at this point for most major apps? I'd imagine they'd have to be. And if I want to take advantage of DirectX10 (as it matures), Vista is the only way to go anyway, right?
re the lowercase 'B'... I'm still living in my T1 world and am always reminding people that transmission is 1.54Mbps vs. 1.54MBps, need to remember the opposite is true with memory... thanks.
Its not opposite. Usually, its understood that when talking about memory, people typing 1Mb really mean 1MB. Now, 1Mb alone, without reference to memory, will most likely be defaulted to 1 megabit, in terms of data size.
Driver and app compatibility has improved greatly over the last 10 months. You shouldn't have any issues with your planned purchases. Also, unlike XP 64 vs XP-32, you should find that Vista 64 works just as well as XP-32 with all apps and drivers. The one exception is with fifteen year old 16-bit applications. If you still use one, you'll need 32-bit Windows.
Mark.
You guys talked me into it... bought another 2Gig of memory and opted for Vista 64bit.
Threw in a new SATA Samsung burner as well, just for the heck of it.
