Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
does it really matter what connection i use. I want the best response time i can get. Will DVI produce better response times then the Non DVI model? The DVI Lcd is on backorder, and i want to get a new lcd.
Makes no dif to response times, only clarity. DVI needs no size or position adjust its just happens (for me anyhow). In other words dont do the analog thingy. it be lookin crappy on my rig.
