Help!!!!!
mattchat
I have diasbled my monitor from my computer from my computer (by accident), i was trying to install the drivers for my new monitor and disabled the monitor its self, what can i do, it loads up and everything, but then the screen just goes black (blank).....
some one please help....
Safemode and delete your monitor and then let it redetect it again.
Startup with the windows options (F5) and try to boot up in VGA mode. Or try safe mode as suggested.
If that doesn't work, which it most likely will, connect your video cards svideo jack to a tv and your screen will load on there. Then you can redo your settings.
Or any other monitor, or the same monitor to another VGA port (if your card has more than one, or a DVI/VGA adapter). Why didn't I think of that?
