Help
SuddenDemise
I have the MSI Neo 2 MOBO, and i have the core center installed(It tells you your CPU and System TEMP and FAN speed) It also displays what MHZ your CPU is running at. Sometimes When i'm watching it i notice that the CPU MHZ bounces Around. Its Supposed to be at 2000MHZ, sometimes it says 1998MHZ and sometimes it bounces to 2150MHZ. Is this bad or is this just something thats normal. Its not heating cause the hottest my CPU has ever gotten was 47 C Degrees. Any thoughts?
