Help
mattman255
i reformated my computer right but i need the sata drivers when the normal blue screen when it says set up sata/raid connection but i am trying to get the sata drivers but the sata drivers requrie to much for a floppy what do i do i need help i tried getting it of the asus mobo board i have but still to much space what should i do help me
specs
amd athlon 3500
74g raptor 10000 rpm single hd
1gig of ocz pc 3200 plantuim rev 1
audioy sb 2zs
600watt enremiax psu
BFG nvidia 6800gt
and on the asus driver disc i tryed only getting sata see if tht would work would that work i need helpp :confused: :confused:
help me
i have a western digtial raptor by the way
First: The Blue Book of Grammar and Punctuation.
(with an emphasis on puncuation)
Second: So what exactly is your motherboard? Does it support SATA?
Third: What do you mean the SATA drivers require too much for the floppy?
Overall: When Windows boots into the typical setup screen, hit F6 a few times to make sure it detects it. If you're on a wireless keyboard connected via USB, put it in the keyboard PS/2 port. Or try a corded keyboard in the same port.
When Windows finally loads all the temporary files, it'll ask you to insert a third-party drivers disk, usually a 3.5" diskette included with your motherboard. Select the correct driver and Windows will load it. It should then detect the hard drive and proceed to install Windows.
1st my main language is not english ok umm
2.Asus A8V
4well i have dsc that only got 1.44mb can you link me some sata drivers plxz
Even if you don't know english, you should know how to use periods and commas.
