help
AMDXP
I applied a theme and i lost the look of my old recycle bin so i finally found it on the net how do i apply that image to use as my recycle bin?
ok so, how do i change the look of only the recycle bin?
I'm not too up on desktop customization but I have used a program called IconPackager. I believe it is strictly used for the replacement of default icons and, for the time I used it, works very well.
The program can be downloaded here.
Themes can be found here.
Right click on desktop, go to Properties.
I forget under which tab it is, but it'll have a button sayinig "Customize Desktop."
In there, you can change the icons for Recycle Bin (empty) and Recycle Bin (full).
ok i dled the old trash icons on my desktop, how to i put them back?
