Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I mounted a 3.0ghz 800fsb P4 on a abit max2 ic7, and it says im running a CPU temp of 50C and an amibient of 37 w/ arctic silver5 and a thermaltake spark 7+
Is that a load temp or idle? I don't think 13 degrees above ambient is all that bad (on air). I think you need to work on case airflow to get that 37 down.
