Looking for a triple monitor display setup.
Wants:
23" or larger
1920x1200 resolution
IPS panel, if possible
Triple monitor mount that isn't too expensive
Not sure:
I don't know if I want matching monitors or not. I'd like to turn at least one display into portrait. This means that I might be okay with a 24" in the middle turned portrait, and then the other 2 monitors on either side as landscape. I could also do 2 23" or 24" landscape and one 20" or 22" turned portrait on the end.
I'm not picky, so I'm open to suggestions.
Budget: I'd like to stick to under $800 for the entire thing. It might be tight, I understand. If it goes a little over that's okay.
I'm not going to be reusing any of my current displays for this. I have a 22" Samsung that will probably go to the wife's computer, and a 19" that will go to my work laptop docking station.
Let's hear what you got!
Wants:
23" or larger
Not sure:
