Help
p.i.m.p
i havent used this PC in over a yr, so i hook er up and problem is
my barton 2500+ reset itself to 1.1ghz - this i fixed
i had 2x512 pc3200 dual channel running @ 200mhz now it only recognizes 1x512 single chan
nothing was touched since i stopped using the pc over a yr ago and i've tested the ram and both work seperately and both are in the correct slots.
any ideas ?
try testing the RAM with the lowest MHz possible, and raising the RAM voltage a little bit
