Help..
KonroKing
I have been wondering if I was to take apart my watercooling loop and refilled it if I would see any temp drops... Rig has been running for about 3 years now and I have not done anything to the watercooling setup since I purchased it...
are you running any kind of dyes or anything in the loop?? If you maybe, might have gunk build up inside depending on the dye.
If not, you probably won't see a difference. If it's been working well so far, it will probably continue to be ok.
my.php
I have attached a reciept of my items I had a few questions aswell I am soon to be getting a 260/2xx card and have read about the GT200 adapter plate for my waterblock but I have the discontinued version and the ones out now are the -R / -Rv2 while they look the same I am not sure if it will work.
picture isn't working. What block is it?
It doesnt have to be that one exact right? I just want to upgrade to a 260+ not a 88xx and I am not going to redo my loop so if this NON-R Swiftech block wont work I dont upgrade
