HELP !!!
GoodGame
umm i just bought a new system and i set everything up and when i turned it on to set up bios it just shut off after being on for like 3 seconds any suggestions :confused:
take out and reseat cards, ram , and lastly CPU. also, make sure your front panel jumpers are installed correctly.
You should try to make your thread titles more descriptive. You'd probably get a better response.
Do you have your heatsink installed on your processor correctly?
