Help
mikeczyz
512 megs of ram just ain't cutting it anymore but I was just at newegg looking for a 1 gig stick of ram and was totally overwhelmed with choices. Here's what CPU-Z says under the memory tab:
Type: DDR-SDRAM
Timings
203 MHZ
CPU/10
3-3-3-8-12-16
What's the deal with ram voltage? And how do I pick a brand? I want to spend between 75-100 bucks, less would be even better. I'm not some sort of memory overclocker so I don't need anything fancy. Just a 1 gig stick of ram that won't die on me.
Thanks!
Mike
Are going to be doing much overclocking? If not, just get some value RAM made by Crucial, Corsair, Kingston, etc.
mikeczyz said:
amd socket 754
do you need to know what my mobo is?
thanks,
mike
i need to know a lot more than that
mobo, cpu, ram, psu, cooling
No overclocking
mobo: Gigabyte k8m800-8273
cpu: AMD 63 3000+ slightly tweaked to 2030 mhz
ram: 1 stick of 512 meg ram...i have no idea what brand....whatever came with the computer.
psu: 450 watt psu, no idea what brand
cooling: stock...3 fans whirring away inside the case...
anything else?
