Help!!!!!!!!!!!!!!!!!!!!!!!!!! !!
SXT14
Hey all I really need help on a problem that recently started happening.
I have an abit KU8 and the problem is in windows xp when I choose shut Down it shuts down and then the computer automaticly restarts on its own. Thanks for the help guys
Check in bios. I belive there is a setting that might be messing around with that. Its the setting with the Restart on power off state or something. What it does is that if your power goes out, when it comes back on, your PC will power on. This is problem one of the first settings i look for. I made the mistke of using keyboard button for power on. I was in a hurry and adding in my new opteron. I had the CPU in, paste on....no HSF and i hit the keyboard (space bar) by mistake....my machine powered up for like 3-4 seconds with no HSF on my cpu....quickly unplugged and checked my CPU. Thank god it didnt get hot enough yet to burn me, just really warm to the touch. Scared the hell out of me.
Also, this might have something to do with it. If you have Wake on lan or Wake on Keyboard. Either one of these might have something to do with it. I would disable all wake and check the setting i mentioned above.
