Help! Zen ST62K keeps randomly powering off
spacey
My gf's Shuttle Zen keeps randomly powering off while you're using it. Its a few months past its warranty (go figure). I can't find anywhere in Canada where you can actually get a replacement power supply... I suspect the problem is the power supply. What else could it be?
Thanks for any help.
What more do you need to know than its a Shuttle Zen? ST62K. I just told you the problem, its powering off randomly during usage. (Probably due to power supply failing or overheating).
Inside is a Celeron D 320 in it with 512 MB 400 MHZ DDR ram... a small IDE hard drive and an optical drive. Its running WinXP.
same answer as you got earlier on www.sfftech.com . CPU is overheating due to a failed fan header on those models. switch to another header (1 or 3I think it is) until it goes out too.
